How many of you are using the COndensor guard from Genos??? Was thinking it might be a good idea since I live out in the dirt and rocks. Says the instillation is pretty streight forward. Any advice and opinions would be great. . thanks!!:-laf
I pulled the left front fender liner to get access to the original horn for removal to make room for the air horns. I made a custom mounting bracket and was able to use the original mounting bolt for the air horns (Hadley Bully). Compressor was mounted to engine similar to Pac Brake unit location. 2 1/2 gal. tank is mounted to bottom of bed struts outside frame forward of left rear wheel complete with gauge and quick disconnect for future air hose attachment.GablerEnt
Not to hijack the thread, but I'm about to install air horns on mine. Any advice on where to put the horns or other advice would be appreciated.
Mine is hung over the condenser, attached at the bottom by two zip ties.
I just don't see anything to zip tie it to. Did you just stick the zip ties through the fins of the condenser and come back and loop through the guard? I know it's a really silly question, but nothing is obvious.
Thanks
