Like Skipro3 said, Take your time and use a rachet set-up with a Torx hex bit, or I used a small 1/4" rachet dogbone wrench with the Torx bit to get to the brackets behind the bumper... ... I did it easily, and I'm paralyzed from the waist down !!! Don't give up, it's a good product to protect the condenser. I put mine on the 06', and it fit perfect. There are oval cutouts on the edge to allow for the Torx screws to be installed when sandwiching the guard between the brackets... ... . it'll only go one way, and all 9 holes lined up perfect..... on mine anyways !!!!If it doesn't look right one way, flip it end for end... It should only go on one way.
RH
