I have been reading the TDR threads for a couple of years.
I have drawn conclusions that:
The lp fuel input goes to the internal VP44 vane pump that raises the pressure for input to the high pressure side of the VP44 that then raises the pressure to injection levels.
The excess lp pressure (over 14 psi that the overflow valve is set for) will be vented back to the tank and helps cool the VP internals.
THEN I bought "Diesel-Engine Management" by Robert Bosch GmbH 2005 4th edition (ISBN 0-8376-1353-1). Now I am REALLY confused.
Starting on pg 214 the Low-pressure stage.
The low pressure vane-type pump takes the output of the lp and raises it to 8-22 bar (116-362 psi) that feeds the high pressure side fo the VP44. It has a pressure-control valve that keeps the pressure from reaching too high a pressure during high pump speeds. However the vane-type pump generates 8 -22 bar (116 - 362 psi) that feeds the high pressure stage.
It also has a overflow valve that "In order to vent and, in particular, cool the distributor injection pump, excess fuel flows back to the fuel tank through the overflow valve screwed into the pump housing. Inside the valve body there is a spring-loaded ball valve which allows fuel to escape ehen the pressure exceeds the preset opening pressure. In the overflow channel to the ball valve, there is a bore that is connected to the pump overflow via a very small throttle bore. Since the overflow valve is mounted on top of the pump housing, the throttle bore facilitates automatic venting of the fuel-injection pump.
The entire low-pressure stage of the fuel injection pump is precisely coordinated to allow a defines quantity of fuel to escape through the overflow valve and return to the fuel tank.
What I do not understand:
In the diagram pages the overflow valve is AFTER the low pressure vane pump. Much we read on TDR says the pressure setting of the overflow valve is set to 14 psi. If the overflow valve is AFTER the low pressure vane pump aren't the pressures up in the 116 - 362 psi range? How can that be?
The diagrams of the fuel system in the VP44 do not show anything up in the low pressure vane pump end that would return fuel to the tank BEFORE it is pressurized.
Which also confuses how more than 14 psi from the lp wound do anything to help cool the VP44 IF the overflow valve is AFTER the low pressure vane pump's 116 - 362 psi.
Maybe the diagram in the book is wrong? 4th edition, doubtful
I will try to get a picture of the pump fuel diagrams.
Bob Weis
DOES anyone
Bob Weis
DOES anyone
