Connector for backup light NV4500 Trans
6 way power seat track
A/C thermostat
Can anyone out there suggest a source for a female connector from the wiring harness to the backup light switch on a 97 Nv4500 5 spd trans, short of buying the entire wiring harness? My local dealer can only order the harness.
I'm in the process of working on that one for you. I'll post the part number if it is available once I find it. I got one a while back for one of our auto to manual swaps.
Chris Timochko
AUTO WURKS DIESEL R&D TEAM
1997 5sp 4X4, Espar Heater, A. W. D. HX40 turbo, ATS 3pc Manifold, BD 4" Brake, Marine Compression, A. W. D. Custom Tuned Injection Pump, A. W. D. Intercooler, A. W. D. 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, A. W. D. Water Injection, NOS Diesel Kit, A. W. D. 6" Chrome Exhaust System, BD No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s.
May be a captive part ,some of the connectors on the d/c are Weather-pac. not sure on the back-up lite.
But if all else fails try salavage yard,there has been many totaled .
One sourse is Weller auto parts $ Neals in Grand Rapids. Should be able to find the number on the net. A lot cheaper then a harness forget about the labor.
Here you go, my Mopar parts man, Artie McAnany at Fairway Dodge in Ridgewood, NJ got the answer you're looking for.
The plug is mopar p/n 4400809
The terminals that fit inside the plug are mopar p/n 4274665 and you'll need two of them.
You're gonna have to crimp/solder your own pigtails to these terminals and put it together as a unit yourself, but it doesn't get better than this.
Chris Timochko
Thanks to Diesel59 and Tdrbramr for the help. I will try ordering through my dealer here, or if that fails, the nearest salvage yard.
Dave Crain
