I have a 2002 CTD 2500. It is not driven in the winter unless its an extreme emergency. This spring I have discovered that the heat will not shut off. The blend door moves with the selector from floor to dash to defrost. fan works just fine. However, no matter where the temp selector is positioned, the vents blow hot air. Even witbh the system set to off, it still emits hot air. I checked to see if the knob was stripped but it seems OK. Was rather uncomfortable today driving 3 houirs to pick up a new to us 5th wheel camper with the outside temp in the 80's....Any ideas or suggestions of what to check.
Thanks,
Bill
Thanks,
Bill
