Container Manufacture for Fuel Additives etc
Traction Bars
LED Cab Marker Lights
I get my Stanadyne PF in 5 gallon cans and wanted a way to break it down into smaller containers easily.
At first I got a 1/2 gallon Stanadyne jug and tried to keep a Stanadyne 16 oz container filled from that and use 8 oz at a fill up. It is somewhat difficult to pour from the wide mouth 1/2 gallon jug into the narrow mouth 16 oz container especially at the pump in the wind, it blows everywhere.
I want my wife to be able to refuel and have a simple "dump one of these into the tank before you pump the diesel then fill 'er up".
I went looking for another way to do this and found the Freund Container web site. They make containers in all sizes and materials in all kinds of different configurations. I looked for a HDPE (High Density Poly Ethlyene) material that is not effected by corrosive materials or oils.
I got 15 1/2 gallon 31064B container (notice it does NOT come with a cap).
I got 10 312089-8 8 ounce wide mouth containers (also do not come with a cap) for each tank fillup.
The tops I got were the X38-400C-WB (they fit both containers and seal really well).
(It takes 10 @ 1/2 gallon containers for one 5 gallon can of Stanadyne and you always have "some" in another can you are using until that can is empty. With 15 @ 1/2 gallon containers I can order a new 5 gallon can of Stanadyne and repackage it all at the same time.
10 of the 8 oz so I can fill enough of them and keep some on the shelf and some in the truck)
One thing you need to be aware of is there is a $10 case break fee if you do not take a total case lot of any item (does not pertain to tops), in this case I had to pay a 2@ $10 case break fees because of the 2 different less than case lot items.
I now only carry 6 of the 8 oz containers and fill as necessary, and take the 1/2 gallon jug on extended trips.
Bob Weis
I use those aluminum camping fuel jugs for my additives. They come in many different sizes, and are made for fuel. They work great.
Powerade or gatorade bottles work good for me. I buy PS diesel kleen and centane boost in bulk, than do a 50/50 mix. I wish you could buy a case of it in aluminum cans just like beer. Crack one open every time you fill up :-laf
