Continuous Water Injection
E320cdi?
Twins, on a Ford...So glad I'm twin-turboing a Cummins!
Have any of you seen this done in this manner before? Reminds me of a water injection unit for gas cars back in the 50's & 60's.
Green Car Congress
February 06, 2005
Trial of Continuous Water Injection for NOx Reduction in Diesel LDVs
Vancouver-based Rival Technologies is working to adapt Continuous Water Injection (CWI) technology to retrofit light- and medium-duty diesel engines for reduced NOx emissions. The company is installing a prototype system on a Dodge Ram pickup truck with a 5. 9-liter in-line six cylinder, 24 valve, turbocharged Cummins diesel engine.
The prototype will be operational this month. Ongoing testing and adjustments are estimated to be completed in May, 2005.
Rival acquired its CWI technology from M. A. Turbo/Engine, which had originally developed it for use in large marine diesels (e. g. , a ferry).
CWI systems work on the principle of reducing NOx formation by injecting measured amounts of water to reduce peak flame temperature. This is related to the new EPA Clean Diesel Combustion engine (earlier post) in concept—i. e. , reduce combustion temperature to reduce NOx formation—but it clearly uses a different approach.
Test and trials of different CWI systems on stationary diesels and marine engines point to a reduction in NOx of approximately 30%, with some wide variation. Engine power and fuel efficiency seem basically unaffected, with some positive increases noted in some of the tests.
Article at: http://www.greencarcongress.com/2005/02/trial_of_contin.html
