Has anyone out there tried Centramatic's Continuous Wheel Balancers? Ever since purchacing my 91 1/2, W250, in 2000, I have had a problem with a front vibration. It will normally show up between, 45-55 mph. I have gone through the normal routine, new tires, front end alinement, wheel balancing and tire rotation. I have even taken the front hubs off to inspect the wheel bearing. It's still there! Sometimes rotating the tire rotation helps alittle. I have noticed that if I jack up the front wheels of the ground and spin the tires, that they will not run true. HELP!!!
