I'm with Mike - in much colder climates, the synthetics offer enough added performance to begin to justify their higher cost - but here in sunny California, no point.
"but I think it all evens out when you consider you can go quite a while between changing oil. "
Also NOT to start another oil war, but what is usually overlooked by most, is the fact that even dino oils will go out to about 32,000 miles and still retain adequate engine protection. Most users, and especially synthetic users/peddlers, are either unaware of or ignore that fact...
YOU DON'T *HAVE* TO USE SYNTHETICS TO EMPLOY EXTENDED DRAIN INTERVALS!
And if you are using extended drain intervals to save money spent on expensive synthetics, you could save the same percentage with extended drains on Delo 400...
BUT, for my money, 5,000 miles or so, and get that used stuff OUTTA there!, I don't care WHAT an oil analysis sez!
