convert ve to p pump cam gear ?;s
Exhaust down pipe
Updated Baldwin Oil Filter Number
therabbittree
I have the parts to convert already, bought them long time ago. . its so long ago that I forgot if the stock first gen ve cam gear will mesh with the p pump injection pump gear correctly or not. . ie i forgot if i have to swap cam gears. .
etc.
I did a search but i could only spend 1/2hr , as I ihave to split for work asap.
thanks,
Deo
thanks Joe. I have all the parts then. . mummn I'm tempted to swap it hehe. . oh well maybe the getrag won't like it though. . I know with 370s and plate slide my old rnv4500 clutch took a slip and that was on a '96 215 pump truck. . oh well it rann nice thoughh hehe
thanks
deo
AS long as the Getrag is set up properly, i. e. not shimmed too loose or tight, it should stand up to what a NV4500 would. And, I have been told the Sachs clutch is stornger than the later LuK. I can verify the 225K stock clutch is better than a new LuK ProGold- BTDT, no fun.
Daniel
I hope so too. . I have a freind that like em and has had over 200 k on on em with out problems. . this is my first getrag . . I had a NV4500 but sold that truck. . I had that clutch slipping with just 370's and stock plate slide forward ... it saw 45 psi pretty often. . I hope this getrag works well. . at least till I can get extra cash to do a different swap in . . I am thinking of a 3 inch body lift and a truck trans???. . its cheaper price wise and I have access to a divorced 205 transfer case. . I still am debating . . not sure if I should dive in or not or just do nv4500 or 5600 swap . . mummn. . oh well
Thanks,
Deo
