DaveHess
I fell prey to what I thought was a sound modification to make. The thought behind the mod is to remove the check ball, spring and restrictor to allow transmission fluid to flow without restriction thus lowering fluid temperature. The only drawback I found while researching this mod was I would need to put the truck in neutral prior to putting it in gear to refill the converter with fluid. No problem as I do not just get in, start it, and drop it into gear. I attempted to drill out and remove the check ball, spring and restrictor in the converter drain back valve. This was an epic fail. I knew the drain back valve was made of brass so I took a hand grinding stone and knocked off the sharp edges of a couple drill bits so that I could drill the brass without having the bit grab the brass. Not so much. So, now I have a question. Has anyone ever tried replacing that piece of transmission line with a piece of 1/2" diameter transmission hose? Using double worm gear clamps on each end of the hose should preclude any leaks. Just wondering if anyone has ever done this.
