Ok guys I have a question, this is especially for those of you with a rig like the wifes (in sig, what you see is what she has no bombs).
I have a HX-35 off a 95 12v. And I want to swap it out with her HY-35. Now in my looking things over today, I noticed a few things that are quite a bit different.
1. The wastegate set up is MUCH different. As those of you familiar with the 12v the wastegate has a vaccum line (assuming thats what it is) that runs from the pump OVER the head to the turbo. The HY has nothing of the sort infact the actuator has a rod connecting it to the outlet (to intercooler) of the compressor side.
Q. Will it hurt a stock engine w/ auto to not have a wastegate hooked up?
2. The ex. inlet (where it meets the manifold) on the 12v has TWO ports, where as the HY on our 24v has ONE monster port. I hope that made sense (did in my head).
Q. Will the HX off a 12v work on the 24v that had a HY on it?
Q. What are the two ports for? Why only one on the HY and and the manifold on the 24v?
Last question, will the stock 24v have enough fuel to run the HX? And if so am I wrong in assuming that it should have a little more kick with the HX instead of the HY?
TIA
Russell
TIA
Russell
