She's been parked an hour. There are no spots on the ground. There's a smidgen of white residue by the #1 exhaust. There's an 8" x 4" wet spot on the black "felt" that insulates the hood above the by-pass hose. There's a small wet spot where the by-pass hose connects to the engine block. That's pretty much it.
Earlier: I tested her by maxing out my RPM's in 3rd gear after a 10 minute warm-up. I felt the governor kick in; 45mph [& nothing more!]; 2900 RPM [& nothing more!]. Okay, that was interesting. Made my way back. After parking, I went to check the temperature of various items in the engine bay using a cheap IR thermometer. Noticed the smell first. Saw the evidence second. [Upper hose: 158*]
Cooling system status: She's been flushed & filled. New 180* thermostat kit [has the two seals] by Gates; new by-pass hose; new short heater hose with the 90* bend; all from Geno's. Inside the cab, the coolant gauge didn't work until I replaced the actual sensor beneath cyl 6 on the driver side. Part made by Airtex; purchased from Rock Auto. [Expensive little bugger - $63 [other models use $6-$14 ones]] . Now the console gauge in the cab rises to about "220*" {the last white line before the red 230 mark} where it'll stay for just about a minute. Then it plunges down to 190*; slowly makes its way back up to 220*; rinse & repeat. I attribute the "higher" temps to the Airtex sensor, but that's why I had the IR thermometer.
Anyway, I'll have to compare temperatures later. I'll tighten the screw on the by-pass hose, and repeat the experiment tomorrow. I'm throwing this incident out here just to make sure all is well. I know from reading other posts that my console temp gauge reads very high for an unloaded truck. I welcome your thoughts on this matter.
