I think it's time to change my coolant as I began to overheat yesterday while pulling only a 8 k lb. trailer uphill. I've been reading about flushing coolant in the forums, but I want to make sure that I do it right. Here is my tentative plan:
-Warm the engine and let the heat run full blast
-drain all fluid in the raidator and reservoir, then close the valve
-fill the radiator with 4 gallons of distilled water and 4 scoops of Electro-sol Automatic Dishwasher powder
-let the engine warm again, then drain the fluid
-fill with 4 gallons of distilled water, drive, then drain
-fill 50/50 of Fleetguard and distilled water
How does that sound? Also, is Fleetguard distributed by Cummins only, or can I get it elsewhere? Should I put in a 180 degree thermostat too? Thanks.
-Tim
-Tim
