Engine/Transmission (1994 - 1998) Coolant Hose Repair
Engine/Transmission (1998.5 - 2002) Auto trans hick-up in/out of OD
Engine/Transmission (1998.5 - 2002) APPS Recalibration - Yes!
On my recent return trip from BC, I discovered anti-freeze on the front valve cover area. It took several tries to locate the source. On the 12V, there is a ¼ inch formed hose that goes from where the thermostat housing bolts to the head and just before the upper radiator hose. There was a pinhole in the hose that did not leak except when on the road, then it would give a fine mist. I almost went nuts trying to locate where the leak was.
Although the leak was a personal problem, I thought I would share with you the fix.
The ¼ inch formed hose was OEM. Try to find that hose on Sunday of a three day weekend. I replaced the hose with a ¼ inch fuel hose, 7 inches long. Due to the position of the hose fittings, the hose must make an arc. Too short, hose will pinch off, too long, rubs too many other things.
I don’t know about cost savings, the fuel hose was in my toolbox, and I see no need to find a ¼ inch formed hose.
Wayne
the young guy at the parts counter of my local Dodge dealer can't ever figure out the part number for that formed hose. I finally saved the plastic bag with the part no. from the last one I put on. on my truck they seem to last about 45,000 miles.
I am the second owner of my Ram. My formed hose appears to be origional (140000 miles) judging by it being painted with engine paint and OEM hose clamps.
Do you remember what you paid for the formed hose?
Wayne
