WhiteSheep
While on the way to work yesterday (9/24), I was 9 miles into a 10 mile commute when I noticed my temperature gauge was about in the red. I was driving with the windows down and there was no smell or sign of a hot engine. I pulled over, shut her down and opened the hood. None of the radiators were hot and the cap was barely warm to the touch. I went ahead and pulled the radiator cap off and was rewarded with a pretty good burp of fluid. Luckily I had left a 6 gallon jug of drinking water in the truck after a desert trip a while back. I used about four gallons to fill up the radiator and off to work I went and then drove back home at the end of the day with no issues.
As an aside, while working on a power steering leak earlier in the week I noticed a weird pink baked on residue all over the front of the engine. I know now I should have checked the coolant level, but I still expect radiator fluid to be green and was focused on the steering issue. My bad. The point is that not all of the baked on spray was from the burp I caused yesterday.
Today I drained the cooling system and inspected the engine compartment. There was baked on spray all over the front of the engine no different than before. I filled the system with tap water and drove it on the freeway up to operating temperature with the heat full on (just under 200 F). No leaks. Parked it and let it idle for a few minutes and again no leaks. This truck has about 90,000 on it stock and while I suspect the water pump, it seems too early in this trucks life for that to be an issue. I wonder if I have a bad cap and it has been allowing "burps" when very hot. Does it do this? I do live in Phoenix, and 115 F ambient is hard on any cooling system. While on a camping trip earlier this summer it did get over 200, probably about 220, but way below the red.
I am letting it sit for the day while it cools and will drain the tap water and replace it with 50/50 distilled water and HOAT and a little leak indicator along with a new cap. After an engine wash I hope to be able to find the leak. What do you think of this plan? Would it be better to just go ahead and replace the water pump now along with new hoses and a new cap?
Thank you in advance for any advice
