My 2006 is developing a small (for now) coolant leak at the front passenger side of the engine block. It appears that there is at least one, small diameter, freeze plug on the front face of the block, just above the oil pan mounting surface and between the timing cover and the air conditioning compressor cast in mounting block.
Before I pull this apart, can anybody tell me how many and what size freeze plugs are in this location?
The head gasket and the thermostat housing are located above this area and do not appear to be leaking.
Thanks
Charlie
Thanks
Charlie
