Well, it's happened for the third time. I'm getting coolant leak around the thermostat housing. (I've verified it's not the head gasket) I have changed the thermostat gaskets each time, making sure the sealing surfaces are hospital clean. I can drive around for 5,000 miles with no leaks, but 100 miles after I start towing my car trailer (6K lbs. ) I get leakage. I'm using Cummins parts, and have even gone as far as using brand new Cummins bolts. (I always use a torque wrench) I think the only thing left is to replacing the thermostat housing, but I can't see any reason for this. Any other ideas?
