I have a 2008 6.7L cummins, I have two issues but not sure of they are related. The coolant issue, Im loosing coolant from the rear of the engine. The top of the bell housing is wet, but Im not loosing a lot of coolant, but enough to make some steam come up from the hood when I stop, but I traveled over 200 miles pulling a trailer and its only a little low on coolant. I just bought a pressure tester but before I test it, is there anything in the back that might be problematic that I can start looking at? The second issue Im having, when I run the engine brake, I get a squealing noise, but if I turn the brake off, it stops. Also no issue when its idling or under power and I have no power loss. Im thinking maybe an air leak of some sort but these two issues started about the same time so not sure if they might be related.
