OK, I've had this leak for about a year and half. I stopped driving the 95 after I bought my 04. 5, the 95 had this bad coolant leak before I parked it. 2 months ago I started driving the 95 to save some "around-town" miles on my new truck. But the leak is getting worse. I would say 1 gallon for every 1000 miles, maybe a little less. Its right around the front passenger side of the engine. I have read a few post that sound similar. I've changed ALL of the gaskets associated with the thermostat and cleaned every part before reassembly. Several times I have washed the engine off in hopes to pin-point the leak, but have had no success. I have come to a couple of conclusions, starting the the less expensive.
1. There is a little coolant line by the thermostat, changed that and tightened the fitting going into the therm-housing-no fix.
2. thermostat and gaskets-no fix.
3. The little freeze plug located on top of the head between injectors #1 and #2, have not changed this.
4. Changed gaskets and cleaned parts surrounding the oil cooler-no fix
5. Head gasket, don't really want to change this, would rather spend money on my 04. 5.
Im guessing its probably #5. So if this is what I resort to doing, what is the expected cost to replace the gasket. Any good mechanics around the Denver, Fort Collins CO area. I refuse to take it to the dealership, Im not stupid!
Any help would be great!
