Coolant Leak
#6 piston hotter than 1-5
Pacific Performance Engineeering programmer
Morning All. .
Smelled the unmistakable odor of glycol when I shut my truck down yesterday.
Restarted it & looked under the hood & saw a fine "spray" of coolant coming from the area behind the fan pulley.
I assume this is the water pump. The truck is an 03' 555/300 w/ st, ac. and has about 83 K on the odo.
Is there a seal in this location that can be replaced, or is this a symptom of a soon-to-be-failed water pump as happens w/ some gassers?
I have no experience w/ this, as I have never had a coolant leak in any of the 3 Cummins engines I have owned to date.
Thanks in advance, Greg
jwilliams3 said:
Are you sure its the water pump?
My front freeze plug was leaking and its right behind the fan pulley mount.
Thanks for the reply jwilliams...
No, I'm not sure... . I didn't know there was a freeze plug at that location. How did you figure that out/ fix the leaking plug?
GG
