MarkEagleUSA
Nothing "wet" that I could tell either. That pic was taken in the morning before the truck was driven. I checked it later in the afternoon after a short ride and still had no wetness... just the gooey mess you see.Assuming that there is nothing wet that I can't see in the picture I would attempt to first tighten the pipe plugs. I believe each one blocks the water passages in the cylinder head.
Someone may not have tightened them properly when the head was assembled.
If you find they are loose I would drain the cooling system down a bit, remove them, clean them up and re-assemble using some quality thread sealing tape or compound.
I'll try to tighten them tonight when I get home. Are those head bolts next to the plugs?
The coolant is green in the radiator. Makes me wonder if the right coolant is in there... oh well, another thing added to the list.That happened to my '07, 5.9. What color coolant are you running? Since I had the factory red coolant in mine, I had reddish white staining.
