JLandry
Hi Ram gang,
I have a couple of questions about draining and refilling engine coolant in my 2014 3500 dually with an Aisin transmission.
1. Is the best / most convenient / acceptable way to drain coolant by removing the fender liner on the passenger side of the wheel well then loosening one the lower radiator hose clamps? I ask because I don’t see a drain valve anywhere.
2. What is the approximate quantity of coolant needed for a simple drain and refill via the above method?
Thanks in advance,
John L.
Thanks in advance,
John L.
