Hi, new to DC medium duty diesels and have some coolant questions. What type/brand of coolant do you use - where to buy it, and can you use Redline water wetter/surfactant with it? What kind of aftermarket filters are in use, what is your experience with them, how often do you use test strips, how often do you drain and refill? What is the best way to clean my cooling system when I drain and refill in the near future? Just running empty in mid 90 degree/50-60 % humidity at 75 mph up mild hills, I see slightly raised temps up to 190-195 degrees on the gauge (don't know how accurate these are?). Is this normal? I'm wondering what are temps going to be pulling 12k lbs wide open up a steep grade if they are already starting to heat up like this? I've heard there is a TSB about a different thermostat - is this what is needed to control temps? Thanks!
Todd
Todd
