RDMueller
I'm getting ready to replace the coolant on my truck and this will be the first time I've done it myself. It seems like it should be pretty straight forward, but there are a few details I'm wondering about.
When I've done this in the past on other vehicles, I remember that the block holds a significant amount of water that you can't drain. Therefore, if you are flushing with tap water, you will be left with some amount of tap water in the system after you fill with coolant and distilled water. I always thought tap water in the system was a no no. On the Cummins, does opening the drain on the radiator allow most or all of the coolant to drain? If not, what is the recommended procedure to ensure you end up with a 50/50 mix of coolant and distilled water, and no tap water in the system?
One other thing, truck is an 01. 5 with 230K miles and since I'm the 2nd owner, I have no idea if the water pump has ever been replaced. Is there a recommended replacement interval?
Thanks for the input!
