Hey Guys,
My truck developed a bad coolant leak this afternoon. When I turned the truck off, I saw that coolant had ran out of the engine on the ground. I started it back up and had my wife turn it off to see where it was running out.
The truck was parked on a slight slope toward the front. I didn't see anything leaking at idle. When she turned the truck off, I heard what sounded like coolant running down inside the engine. I'm not sure if that's normal or not.
Several seconds after the engine shut off, coolant started pouring off the front of the motor. I couldn't tell where it was coming from, but it was all running off the front passenger side of the oil pan and the bracket right next to it.
What do you guys think might cause this? I pulled out fast a couple times this morning and probably saw 55psi boost, but that's not abnormal. Any ideas? I'll try to get photos and hopefully video up here in the next few minutes.
Thanks!
Thanks!
