Engine/Transmission (1998.5 - 2002) coolant sensor - again? - or something else
2nd Gen Non-Engine/Transmission Bilstien shocks
2nd Gen Non-Engine/Transmission Missing Fuse
After 90,000 miles or so, my LP went dead and my DC dealer changed it under warranty, so I was happy. I picked up the truck on a Friday and by Saturday my check engine light came on, but the truck seems to be running just fine. Monday I took it back to the dealer to have them check it out ... they read the codes and said that the coolant sensor went bad ... changed the sensor and I was happy again. That was about 3-4 weeks ago.
Last week all of a sudden my check gages light goes on with the ringing of the bell and I see that my temperature gage shows 220 and then it drops down to 0 and back again; the check engine light goes back on and the gage returns back to 190 where it should be.
By now (thanks to TDR) I can check my own codes so I pull over and check:
PCU - 1693 DTC detected in ECM or PCM
ECU - 0117 ECT Sensor Voltage Too Low
ECU - 0217 Decreased Engine Performance Due To Engine Overheating Condition
The check engine light stayed on for a little afterward but went out again; and now the truck runs just fine.
It very much looks to me that I have another bad coolant sensor, but nothing on this great truck should go bad in 3 weeks!
What else could this be? Any leads or ideas are appreciated.
Csaba
my gague did the same thing plus i was loosing coolant and it ended up being a blown headgasket. also the pigtail wire between the harness and the sensor when bad on mine, $20 from the dealer, hope this helps some. josh
