JArgo said:
Zach, Could you let me know an approx. price to have my heater core and evap. core replaced so I dont get ripped off to bad
Where, generally, do you live? Soem of the list members will know reputable shops. But a shop in Paducah won't help you much if you are in Fairbanks.
If you live in a place where you can do without the heater, you can bypass the heater core for a while. (Flush it out with water, which you can do from inside the engine compartment. ) I live in Arizona, so that's easy for me to say. My daughter would testify to the coats we wore when driving through Colorado a few Decembers ago.
You can have the smell without the drainage out the HVAC box. It only takes a little coolant to smell awful. You might go months and months before your coolant level drops half a cup full.
Whether you do it yourself, or have it done, you will avoid future squeaks if you also replace the plastic sockets that the dashboard screws go into. They cost about $3 each at the dealer. Also, use a MoPar evaporator. The knock-offs don't fit right. The act like they fit right, but will slowly leak refrigerant out of one of the connectors. Make sure, also, that the ground circuit from the heater core to the chassis is tight. Mine wasn't, and I think that contributed to the smell. If you do it yourself, a 3/8 inch diameter 36 inch long dowel will be your friend.
Go ahead. Ask me how I know this stuff.
