Ok guy,s this is my first post here and I hope I am doing this correctly. I just bought a new to me 96 5 speed truck with 85000 mile on it and was doing some maint. on it and realized that the thermostat housing was leaking a little so I thought that I would get the new o-rings and a new t-stat and just replace the everything while I was in there. I get the job done and take it out for a test drive and the temp. guage goes to 190 deg. then it falls back to 150 deg. as the t-stat opens, everything seems to be fine except it keeps doing this 190 to 150 about every 2 minutes. I know that this can't be good on the motor with this much variation in temp. I took the truck to work and hooked it to our antifreeze reclaimer and purged the system backwards because I thought it still had some air in it. I took it out and drove it abou 40 miles and still the same, so I pulled the new t-stat out and out the old one back in, purged the system again, still the same. I then pulled the fan off thinking that maybe the clutch on it had failed and was locked tight because when the truck was cold the fan still moved a lot of air. It was still the same. I am now out of ideas and I need some help or suggestions, any ideas or experiences will be greatly appreciated. Thanks in advance
MGarland
MGarland
