cooler install
Ordered an AirDog: Install Tips.
how to clean the sensor in the turbo inlet tube
I would like to install a transmission cooler and would like to know where is the best place there is not enough room in front of the rad. I think a good place would be just before the heat exchanger and bypass valve and then route hoses back to just under the floor of the rear seat (this cooler I have has a fan). Any input would be helpful.
Puller
I mounted mine under the cab,just behind the T-case with the fan facing down(blowing to the ground)... works fine so far. . only towed my camper once,kept my trans temp at about 150* to 160* in slow moving traffic... Rich
