Last nite ran into a problem where I saw alot white smoke coming out of
exhaust. I also saw that coolant mist was spraying on the exhaust below
the turbo. Later I could feel/see it was coming from what appeared between the cylinder head and block. I also noticed the top of the radiator was cold
how ever as I opened the radiator cap it was rapidly discharging steam into the overflow tank hmmmm. Once I slowly vented off the steam from the radiator, it
was approximately a gallon low. I am anticpating that the head gasket needs
to be replaced. Will I need to do the cylinder head rebuild? Also I am thinking that the thermostat needs to be replaced. How do I know if the water pump failed. The head is original and there is +200,000 miles on the truck.
Any feedback would be appreciated Thanks
Andy
Andy
