I bought a 98 a few months ago, temp gauge has always read right at 190 degrees. when pulling a 5 ton load the other weekend on the interstate, the temp went up to to around 220. If I pulled over or slowed down to 60 mph, it would drop to 190 in about a minute. Was told radiator is probibly plugged, but looked it over and didnt see much in it, sprayed it with cleaner and flushed with hose. I also replaced viscous drive fan hub and flushed radiator, when pulling a load it still heats up if outside temp is over 75 degrees, below this and i can run 75MPH all day with a load and the temp gauge stays at 190. Any other ideas?
