Engine/Transmission (1998.5 - 2002) Cooolant Filter & coolant flow
2nd Gen Non-Engine/Transmission Bilsteins with Skyjacker DS25
Engine/Transmission (1994 - 1998) HX40 Boost Pressure
I am going to add a coolant filter in heater hose line. What is the flow direction ? Does it flow fom the short hose on the block to heater core then from heater core to lower radiator hose area. :confused:
I think the heater water returns to the lower radiator hose area like you said. Not sure but you could run it and pull a hose off for a second to verify (engine cold). BTW, where did you find a coolant filter? I knwo the big rigs run them.
The hot water comes from...
the front of the head, just before returning to the radiator through the top radiator hose.
