Steve... .
I have on the Cooper Discoverer ST's not the STT's and love them. They now have about 25,000 miles on them and are not even half worn yet. I am running the 265/75R16 load range E(stock replacement size) and keep the pressures adjusted and rotate them regularly. One thing to keep in mind about excessive or extreme wearing tires is load rating. When most got to a off-road style such as this and a larger size than stock load ranges are not where they need to be to accomadate the weight of the truck and will cause excessive wear.
Now,does this mean not run them,certainly not, its your truck,but keep in mind the consequences of your decision and understand the faster wear pattern. Once going to a agressive style tread it is always better in my opinion to do some research and find a set load rated for the truck or capable of handling the weights(example-some D rated tires do have a proper weight handling ability,but,will not be 10ply). Another thing to keep in mind is towing and those lighter weighted tires and the softer sidewalls which will produce more side sway and heat to build faster.
You hear more people complaining of excessive wear and once you look the tires over they are not rated for the truck. Your truck,your decision, look the specs over well,listen to the masses and stand by your decision. Hope this helps... ... . Andy
