Hi,
I have my first Diesel and was told about keeping a eye on the Fuel PSI, but have read a lot of different numbers on several sites.
I have a 1999 with a Hot Rod VP pump and a stock replacement in take lift pump and a aux lift pump on the frame rail
with the stock replacement PSI will read about 7psi at idle if I get on it it will go down to 2psi
with both pumps on it will be around 12 psi and go down to 8 or 9psi win I get on it though after running both for a while it starts to bounce from 5-12psi and then I shut off the aux and ti stabilizes at 7 again
so what psi should I be trying to maintain?
should i be getting a better lift pump?
should I use both at the same time or only the stock replacement?
Thanks for info,
Thanks for info,
