Engine/Transmission (1994 - 1998) Correct HX-40 turbo?
Engine/Transmission (1994 - 1998) 150,000 mile rebuild time
The RV and medium duty applications must all be modified to work in the pick-ups. The wg arm is not oriented correctly to fit.
Bob
well, the only HX40w applications are medium duty/RV applications...
just use the bracket and wastegate actuator from that application... you'll have to bend the wastegate signal tube to match the forward facing actuator.
Forrest
If you send it to PDR for their massaging, they will mod the bracket for a minimal charge when they do the other tricks, they did mine cheap enough that it wasn't worth my time to get the welder out. All HX-40's need to have the bracket modded to fit our trucks.
I think on the manual transmission trucks you can use the WG off the heavier application. On an auto with the heat exchanger in the way I do not think you can do this.
