correcting speedo
Pro's & Con's for new truck
Correcting m.p.g. for 285's
I put 35/12. 5R17's on my truck and almost got a ticket already so need to get my speedo corrected. The dealer can do it right? I have heard that they can but they need to know revolutions per mile, I think that I have the correct formula(34. 6X3. 14/12= circumference in feet) and 5280/ circumference= revs/mi. I came up with 586 revs. ? is this correct?
Just take it to your dealer. They will do the math and reflash the unit. Most will charge you about 1 hour labor. They should do it while you wait.
I wouldn't bet the dealer would (or could) do the math. This is a great website for figuring out speedo error caused by changing tire size.
http://insightnl.extra.daimlerchrysler.com/
it shows your 275s as having 627. 17 RPMs and
315s and having 586. 93. This would give you about a 6. 5% error. IOW, at an indicated 60, you will be actully doing 64. 70 would be 74. 5. Not really a big error margin. If, however, you, like lots of folks, like run the limit plus 5, at an indicated 75, you would be doing almost 80. That would likely get you pulled over.
