Originally posted by Huff N Puff
Start with leaks on the intake side and the exhaust. Dirty oil can slow down your turbine. Injectors not working properly,dirty air filter or dirty fuel filter,poor primary fuel delivery,e. g. lift pump. Those are the simple issues,the complcated ones are sensor or computer problems,and even transmission issues such as slightly slipping transmission components,Good luck,hope its dirty oil. Merv
Originally posted by lpearson
I just put on a new AFE Stage 2 air system and my boost pressure went down from 36 to 34. I guess I don't understand. I didn't do anything else. What gives? I thought more air would increase boost. Anyone got an answer?
Thanks,
Lowell
Originally posted by ndurbin
I also lost 2 lbs. of boost when I installed mine. Went from 26 to 24. I made sure all boot connections were tight.
I am trying to understand the posts here.![]()
So, are you all saying that it's a good thing that the boost pressure went down?![]()
Performance is the same, drives nice, no problems there. Just the boost question.
Interesting note: I thought that higher boost presure = more H. P.
I get a hight volume air system, boost goes down, but performance doesn't.![]()
Anyway, thants for the thoughts.
Lowell
