Started the truck the other morning it usually instantly fires. It stumbled a couple times but started and sounded fine. Took off pulling my boat taking it easy and all of a sudden it took off like i hit the accelerator.
Continued and it ran like it had no boost and the longer I applied the throttle it would "wake up" and run normal. Then once I let off it would start over again.
Codes are PCU 1693 and ECU 0237 Check engine light is on.
Looked this up and one YouTube mentioned his map sensor was the cause and he showed a deteriorated "O" ring. Thoughts???
MAP SENSOR - CUMMINS ('01-'02, 5.9L)
Item #: 4921505
Item #: 4921505
