SnoKing
Well my truck clicked over 100K last year and at 34K I installed a custom DTT towing transmission, Jammer 1's, Comp in EZ mode, Banks 4" Exhaust brake among other things.
The truck got the best mileage ever on out trip from Northern Washington to Arizona after Christmas, getting over 12 MPG on each tank. Combine weight was 20,600 or so.
After getting here I started noticing first thing in the morning while running very slowly in the RV that it would try to shift out of first gear and flair a bit and end up back in first gear, and then repeat it once of twice again. The rest of the day it shift fine. I check codes and see nothing besides that normal ones that the DTT transmission always sets. It has been a while since I have changed the Amsoil transmission fluid. I does look nice and red and level is correct. Any thoughts?
The other issue showed up a few weeks ago. The Banks exhaust brake has a warm up feature that applies the exhaust brake at start up to help warm up the engine until water temp gets to 140 degree's. What is happening is that after a cold start if I put it into gear with the exhaust on it loads and lugs the engine down and puts out black soot! Note TC is a 89 percent DTT unit, that has always been pretty tight!
I have never seen the engine idle slower than its normal RPM before. I am wondering it the bleed hole in the EB butterfly is sooted up. Trying to remember if there was an adjustable stop on the butterfly that has worn and needs adjustment. Again any thoughts?
Snoking
Snoking
