Battling near-100-degree heat, "The Wolverine," driven by Keith Lockliear, practiced a couple of impressive launches, then the truck was parked in the pits.
(A best 60-foot time of 1. 32 seconds hints at this vehicle's true potential. )
After dark, the Cummins-powered machine returned to the Christmas tree. The truck's characteristic diesel-rattle-at-idle quickly gave way to the jet-engine sounds of its exotic turbo system spooling up. Producing a classified amount of boost, the engine ejected the intake hose off the turbo housing before mid-track. Even so, the truck coasted to a best e. t. of 11. 03 seconds @ 91mph. Further inspections revealed that the massive amounts of power actually caused the turbo housing to rotate on its mounts. Edge and Diesel Dynamics took corrective measures, and the truck was later able to run a 9. 77 quarter mile during a test session in Las Vegas.
The Wolverine gave Utah diesel fans a taste of the enormous performance potential in modern "light-duty" diesel engines. Thirteen months in the making, this top-secret project was conceptualized in early 2003 by Edge Products, a leading manufacturer of diesel fuel-management computer upgrades/"chips. "
"Our goal was to produce the fastest, most powerful diesel race vehicle ever seen," says Edge CEO Paul Lehman. "Most people said that the sheer weight and mass of a diesel engine--about 1,100 pounds--would keep the truck from getting anywhere near Pro Stock-type times. We accepted this challenge. "
The tube-frame chassis was fabricated by famous NHRA car builder Jerry Bickel. While the motor is based on a 5. 9L Cummins six-cylinder diesel from a 2004 Dodge truck, only the block is factory-issue. "When something breaks, we can't run over to Pep Boys and get replacement parts," Paul Lehman explains.
Although the engine setup is proprietary, driver Keith Lockliear lays out its underlying theory in lay terms: "We stuff a bunch of fuel to the engine, figure out how to feed it even more fuel, then play with the turbo and boost till we get what we call 'mega mental' amounts of air and boost to burn all that fuel. " Tongue-in-cheek, Paul Lehman adds, "And it gets 20 mpg in the process. "
Lockliear is The Wolverine's sole driver. In fact, the seat's carbon-fiber shell was form-fitted to his body. "If this weren't a diesel-powered truck, I'd have to say that driving it is a gas," Lockliear deadpans.
As the exotic drag truck gets dialed in, it'll appear at selected events through the fall and winter, making occasional exhibition passes. No word yet whether a Wolverine assault on the Bonneville salt is in the cards.
Edge's Paul Lehman concludes, "After a lot of all-nighters, it was great to finally see the truck on the track. We still have some fine-tuning to do, but we wanted to give people a taste of the enormous performance potential possible by applying modern technology to a farm-bred diesel engine. We won't stop till we get into the sixes. " For more information on The Wolverine and its schedule, please visit
www.edgeproducts.com.
EDGE PRODUCTS WOLVERINE
"PRO STOCK" DIESEL DRAG TRUCK
Project Goal: Build the world's quickest diesel-powered vehicle.
Est. HP: 1,100+
Est. Torque: 2,500+ lb-ft
Target e. t. : 6. 50 seconds
Current Best 1/4-Mile Time: 9. 77 seconds
Vehicle: Jerry Bickel Race Cars-built custom tube-frame full-size drag truck
Body: Fiberglass full-size Dodge Ram short bed
Paint Scheme: Designed by Greg Ozubko
Painter: Jerry Bickel Race Cars
Paint: House of Kolors
Engine: Edge/Diesel Dynamics highly modified 2004 Dodge Cummins 5. 9L diesel
Aspiration: Turbocharged (boost level classified)
Max EGT: 1,450 degrees
Safety Equipment: Stroud harness, parachute; halon onboard fire-suppressant Steering: Jerry Bickel
Suspension: Bickel/Koni coilover shocks
Brakes: Strange steel vented discs
Tires: front - Goodyear 26x4. 5/15 rear - Goodyear Pro Mod 34. 5x17. 0/16
Wheels: front - Weld 15x3. 5" Aluma Star rear - Weld 16x16 Aluma Star Double Bead-Loc
Wet Weight: Too heavy to lift.
Edge Wolverine Race Team:
Keith Lockliear, driver
Lenny, head engineer
Mike Cary
Lewis "Dale Jr. " Hilliard
Joe Donnelly
Cord Reynolds
Cade Reynolds
