EZeis
I've been thinking about adding a 2 micron filter and a 8 micron water separator (heated) between the CP3 and the OEM filter/heater assy. With the OEM lift pump. Both fleetguard, FS1212 and FS1003. BTW, truck is stock down to the air filter.
I've read all the threads on 2 micron filters and pressure drops and such. My question is what happens if the lift pump fails with the OEM system system? Does your CP3 burn up? What happens if the OEM filter plugs? Does the CP3 burn up?
I've heard GM trucks run the CP3 without a lift pump. Good sign the CP3 won't burn up easily.
So if adding more filters to the OEM system with the OEM lift pump, wouldn't you have engine performance issues long before you waste the CP3?
I may have overlooked this, I didn't see much mention on the CP3 fuel supply specs. I would think as long as you have flow even 0 psi, the CP3 would still be able to build high pressure for the rail.
Anyways, I guess that's what I'm really after, the CP3 fuel supply specs and what happens with low or no flow and what kills these pumps?
Thanks,
Earl
Thanks,
Earl
