cp3 leaking
dealer can't find part no for FCA , can someone help?
Flywheel Torque Specs?
My cp3 pump is pushing fuel out were the pulley bolts on. Is there a seal or a o ring i can replace or do i have to replace the pump? Only has about 15,000 on it.
cummins the dual setup came from ats and its the pump that came in the kit thats leaking. Do you know were i can order the seals from?
The seals only come in a kit, the inside seal is very hard to replace without breaking down the 1st section. a snap ring needs to be removed and placement of the 1st seal is critical.
