Cp3 pump gearcase timing 04.5
Clutch slave cyl.
FREE Smarty S06 POD upgrade?
My buddy just put an cp3 and injectors in his truck well it was done for him sincei wasent able to help do it now no start its getting fuel up to the injectors but nothing else im looking for any suggestions. And a diagram possibly for gearcase timing and finally its pulling a power data loss code po2509 tia
2509 is power loss to PCI , vehicle still should start,Have your Buddy call Me. . You can post the fix after its up and running,. 763-228-7121
There is no timing the CP-3, only phasing it to the compression strokes.
Make sure all the harnesses are connected good and tight. Sounds like there is one thta is not.
