After returning from a cruise three weeks ago my stock (unmodified) 2003 3500 6 speed 4x4 with 113000 miles would not start. No codes in the OBD, so I assumed that it was the transfer pump. The local Carquest was able to get me a new Carter replacement pump, the truck ran for three days then again would not start. I changed the fuel filter (which was black) again it ran for about three days then would not start. A pressure test on the out side of the fuel filter showed 8-9 lbs pressure and low volume. I returned that pump and ordered a FASS DDRP-04 kit to mount on the frame. The truck now runs great but is slow starting, it seems to me that it is cranking longer than it did before my problems (cranks about 10 to 15 seconds before starting).
I want to put a pressure gauge in the fuel line and feel that the gauge shoud be between the fuel filter and the high pressure pump, not on the fuel filter top where it measures the in pressure only. I have gone back through my TDR magazines and can not find where anyone has put a gauge on the line between the filter and the High Pressure Pump, is there a reason that I am missing?
Also in issue 62 of the TDR, HuffnPuff from Springfield VA refures to a check valve in the return fuel line. I have the MOPAR shop manual and cannot find a check valve in the return fuel line (is it the Cascade overflow Valve). Any help and suggestions would be greatly appreciated. C Pence
