Engine/Transmission (1998.5 - 2002) Cracked 53 block and engine temp.
Engine/Transmission (1998.5 - 2002) Help
2nd Gen Non-Engine/Transmission cruise control
An obvious sign. Stopped at local Cummins shop a week ago and a motorhome wheeled out of the service and pulled up to camp in the parking lot.
Overheating on the road. Cummins did a coolant system pressure test ... failed. i asked service manager if it was a 53 block. He assumed it was but it was covered under Cummins warranty and was replacing it when they got a new engine.
I called Cummins when the 53 issue first surfaced on the TDR. I asked about possible preventions, and the guy replied there really isn't one, but don't overheat it and keep good antifreeze in it. FWIW
Dan
Originally posted by klaybus
Did your 53 block crack with high water temps?
Clay
No. :eek: I was driving a truck with a 53 block. I noticed the temp climbing so I stopped and upon inspection noticed that the fan clutch was toast. I am just wondering if I wasn't paying attention if there is a possibility the block would have cracked due to the heat. Maybe its happened to others without knowing.
I lost a 53 block on my '99 so I can relate what happened on mine. About a week before I found it I started smelling anti freeze when I got out of the truck. I looked for anything dripping on the ground and kept checking the radiator to see if it was low, nothing that I could see. On a weekend trip with the slide-in on board and a 4 place trailer with 2 machines in tow I headed into the mountains. Since I work the graveyard shift we travel in the middle of the night. I had just started pulling a grade when the heater started blowing cold air, the temp gauge was still in the normal range so I thought that I had just run through a cold spot. Then the temp gauge started climbing, I found a wide spot in the road to check things out, this time I could see a leak. I had anti freeze with me because I was suspicious of the smell so I topped things off and went up the road to the next lodge where we spent the night. The next morning when I could see things a little better I found the crack, I bought a couple of gallons of anti freeze and loosened the cap and headed back home after calling a friend to let him know that I might not make it all the way back.
I made it all the home and first thing Monday morning I took it into the dealer where I got a new short block installed.
Gus
