Hi guys, I need some opinions. I have owned my truck going on three years. After owning it for a couple of months I noticed that the underside of the air intake hose from the air filter to the turbo had a crack in it..... 2 to 3" long right where it hooks onto the turbo..... not good!! I replaced the hose and continued to run it (this hose by the way is no longer offered by our friends at dodge!!).
Two years later the truck seems to run fine, doesn't puff smoke etc. My question is, how can one tell how much internal damage this unfiltered air may have caused?? Can you do a compression check on a diesel? The crack was on the underside so it shouldn't have been gaping open, plus my driving is mostly on pavement and we don't use much sand/salt on the roads up here... . rains all the time!! I'm just worried about wear and tear on the rings.
I need to shell out for a new injector pump in the next little while as I just noticed that my throttle shaft is starting to 'seep' a bit of fuel. Should I keep dumping more money into this truck or sell it before I have any future engine problems?? I have already spent the money on a new trans and numerous other wear and tear items on the truck. I noticed a bit of grime on the fins of the impeller but the edges of the fins themselves seem smooth when I look inside the turbo.
Any advice would be appreciated.
