Cracked oil pan and vibrating
Which Southbend for my 2008 Ram4500???
Are EGR free engines in our future?
Can anyone help me out ASAP I have to go to work but my truck is been leaking oil I found out that my 2008 2500 Cummins 6.7 L has a hairline crack on a nicely painted oil pan just above the crossmember it is also vibrating very hard there so I was wondering what causes the vibration if that’s normal and if there is a quick fix I can use for the next eight hours just to get from point a to point B and then I will get a new oil pan or take it off and weld it as I am a welder
Sounds like a big internal problem. I would not recommend driving it at all. Put it on a tow truck and get it in a shop.
Sounds like your engine mite be ready to spin a rod bearing or throw the rod.
But check your vibration damper, it mite becoming apart.
On 78 ford van started to vibrate it eventually spun a rod bearing. It had 237,000 on it . I put 181,000 miles on the 460 engine.
