2nd Gen Non-Engine/Transmission Cracked Rear Brake Rotor
Engine/Transmission (1994 - 1998) best options for economy and power
2nd Gen Non-Engine/Transmission Front Hub bearings?
After removing the rear rotor on the Driver's side, I noticed a crack running from the hub area up through the hole for one of the wheel lugs. I am in the process of replacing the axle seals and bearings due to a leak. Is it safe to reinstall this rotor? Should I install in and get a new one ASAP? Or should I not drive it at all?
Of course this has to happen at 6:00PM on a Saturday night!!!
Thanks for the responses.
If it were me I'd install it and drive very gingerly to the nearest location I could get one. Unless I had another vehicle to shag the part with. Might be a good idea to call ahead to ensure it's in inventory. JMHO
Cheers,
Steve J
