Archived Cracked turbo housing
Archived Ignition key In Column - Will not turn!!
Archived help part discontinued
Well... I went to fix what i thought was a exhaust manifold gasket leak... . but it turned out to be a Crack in my Turbo Hot-side housing... . does anyone know where i can buy just the Hot-side housing?? Or does anyone have a stock turbo laying around that i can buy??... . Any info would be great!. . My truck is a '04. 5 HO..... THANKS!!
TANK
<a href="http://s74.photobucket.com/albums/i264/HELUVJEEPS/?action=view&current=054.jpg" target="_blank">#ad
</a>
<a href="http://s74.photobucket.com/albums/i264/HELUVJEEPS/?action=view&current=057.jpg" target="_blank">#ad
</a>
If you don't have any luck with finding the part or a used turbo, you might try breaking it down and taking it to a weld shop. They may be able to save it for you by drilling out the bad section (so the crack doesn't spread), heat with a torch to get red (so the weld will penetrate) then stick weld.
Looks like a sprue or riser from the casting. That's a first for me.
Find your friendly local Cummins dealer, They may have a housing from a core they could swap out (or any other various turbo shop).
